08-15-2025, 02:15 AM
Call of Duty Black Ops 6 Zombies introduces Reckoning, a chilling yet exhilarating map that tests your tactical instincts and survival skills. One of the most essential mechanics in Zombies mode is the wall buy. Knowing the locations of wall buy weapons, understanding their strengths and Black Ops 6 bot lobby setup timing your purchases can mean the difference between staying in play or becoming zombie bait. In this guide, we walk through the various wall buy locations, offer strategic insights into when to invest, and help you craft a weapon upgrade path that keeps your team coming back toward the round after round.
Reckoning’s environment offers several strategic chokepoints—narrow corridors, upper walkways, and open courtyards where hordes converge. Wall buy weapons are placed just offset from traffic patterns, but located at key junctions where players can grab them and keep momentum going. The first area most newcomers will encounter is the tram platform adjacent to the map entrance. Here a wall buy machine is tucked behind a low barricade. Weapons here are typically mid tier such as assault rifles or submachine guns. This is a great early stage location: zombies trickle through gradually, and you can pick up a handy weapon for a moderate cost. Especially on solo runs, replacing a pistol with a wall‑bought assault rifle can help you conserve ammunition and face the waves more confidently.
Moving deeper into Reckoning, a narrow service corridor leads from the tram zone to a central hub chamber. In this cramped passage, you will encounter another wall buy point, mounted on a crumbling wall just past a set of stairs. Expect weapons like shotguns or burst rifles. The tight enclosure makes these weapons effective against clustering zombies, particularly if you can utilize stair cover. The strategic insight here is that these wall buys are not just about weapon type, but also placement. When you are funneling zombies up the stairs, using a shotgun wall buy point blunts the horde and buys precious seconds.
Proceeding from the hub, you enter an open courtyard with columns and collapsed statues. At the far end is a wall buy station on a pillar near a broken wall. This is a mid‑ to late‑game area, where zombies spawn more densely and more frequently. Weapons here often include higher tier possibilities such as light machine guns or higher rate burst rifles with more ammo capacity. Buying here can help sustain prolonged engagements, particularly if paired with upgraded ammo mods or a Pack‑a‑Punch upgrade delivered via a nearby teleporter or mystery crate drop.
Continuing your journey, you come to an elevated balcony that overlooks the courtyard. On the balcony’s inner wall sits another wall buy point with weapons like upgraded variants of assault rifles or precision sniper rifles. Though sniper rifles may seem slow for Zombies, their long sight lines benefit players defending against waves from the courtyard below, especially when teamed with explosive traps or environmental hazards. Standing on the balcony grants superior visibility and provides control over zombie flow, particularly when combined with a sniper wall buy.
Lastly, the deepest recesses of Reckoning—accessible through a locked door requiring a key or completing a side‑quest—lead to a hidden underground chamber. Here you will uncover the most powerful wall buy station on the map, often featuring powerful burst‑fire weapons or energy‑based variants that deliver high damage and ammo capacity. Though costly, investment here near the later rounds pays off in survivability, especially when positioned near the final holdout zone or boss encounter area.
Timing matters. Early rounds call for affordability and flexibility: pick up weapons during initial traversal of the tram and corridor area. Mid rounds allow room for aggressive weapon swaps in the courtyard and balcony—especially if you have saved enough points or diverted zombies efficiently. Late rounds justify the steep cost of the underground wall buy, particularly if you are sustaining high zombie counts or need precise, high‑damage output.
Tips for maximizing value from wall buys include conserving ammo until you approach a next station so you can swap weapons freely, coordinating with teammates—who may carry different weapon styles—and always keeping escape routes in mind. Avoid spending all your points at one station if that means you cannot open a necessary gate or access a faster route to regroup.
In summary, the opportunistic placement of wall buy stations across Reckoning demands strategic choices. From early game tram platforms to mid‑game courtyards, balconies, and hidden underground chambers, each location offers specific benefits. Understanding when to purchase, what kind of weapon fits each zone, and how to coordinate those buys with team flow will elevate your Zombies experience and greatly increase your survivability. Conquer Reckoning wall buys, and you conquer the map.
