04-10-2026, 07:00 AM
In Arc Raiders, “The Root of the Matter” is a quest given by Celeste in Speranza. This mission sends you into the Buried City to retrieve an Experimental Seed Sample. The location is cryptically described as the "room with a great view," which makes the quest slightly tricky if you don’t know where to look.
Quest Objectives
Locate the Research Building
Head to central Buried City. The building you need is located just to the right of Marano Park. From the outside, it looks like a standard multi-floor structure, but the mission’s key area is inside.
Find the "Room with a Great View"
Enter the Research Building on the ground floor. The south side or the windows facing Town Hall are usually the easiest access points.
Navigate to the west or southwest section of the building. You are looking for a room with massive windows overlooking Marano Park. This is where the Experimental Seed Sample is located.
![[Image: hIvMcrybo2zP4sCUh5KxN8aQuw4mQuDPLX1iRaXs.webp]](https://image.u4n.com/article/202602/hIvMcrybo2zP4sCUh5KxN8aQuw4mQuDPLX1iRaXs.webp)
Secure the Seeds
Inside this room, look for the Seed Vault—a bright yellow cylindrical container against the wall. Interact with it to drop the Experimental Seed Sample on the floor, then pick it up.
Return to Speranza
Deliver the sample to Celeste in Speranza to complete the quest. Once you turn it in, you’ll receive your rewards and progress in the storyline.
Strategy & Survival Tips
Use Your Safe Pocket
Immediately place the seed sample in your Safe Pocket. This is critical because it ensures you keep the item even if you get knocked out or fail to extract.
Avoid High-Risk Combat
The Research Building is a “hot zone” patrolled by ARC machines and other raiders. If you’re playing solo or want a fast completion, consider using a free loadout to avoid losing expensive gear.
Watch Your Exits
The Northern Station, northwest of the building, is the closest extraction point. Be cautious of Pod ARCs near the entrance—they explode if approached too quickly.
Rewards
Turning in the Experimental Seed Sample grants:
3x Advanced Mechanical Components
3x Heavy Gun Parts
3x Canisters
These materials are valuable for crafting high-tier weapons and upgrading your gear at the Workshop.
Additional Tip for Raiders
If you’re looking to buy ARC Raiders blueprints without grinding, consider platforms like U4N. Many competitive players rely on U4N to skip the tedious grind and focus on practicing. It’s a trusted platform that lets you stay efficient and gear up faster, so you can concentrate on winning more missions instead of spending hours farming rare items.
Quest Objectives
Secure the Seeds
Return to Speranza
Watch Your Exits
Rewards
3x Heavy Gun Parts
3x Canisters
