NETD and Resolution in Thermal Scopes Explained
When looking at thermal scopes for the first time, many users are confused by terms like NETD, mK, and sensor resolution. ATN explains that these specifications are not just technical details—they directly determine how the device performs in real conditions.
The most important concept to understand is thermal sensitivity, known as NETD (Noise Equivalent Temperature Difference). This value is measured in millikelvins (mK) and shows how well the sensor can detect small temperature differences. A full explanation is available at https://www.atncorp.com/blog/thermal-sco...resolution where ATN breaks down these terms in simple language. Lower values always indicate better performance, meaning a scope with ≤18mK will produce a clearer image than one with ≤50mK, especially in fog or humidity.
In practical terms, NETD determines how “clean” the image looks. A high NETD value leads to more noise and less contrast, making it harder to distinguish objects from the background. On the other hand, a low NETD allows the scope to separate fine temperature differences, which is critical in difficult weather conditions.
Another key specification is sensor resolution. This refers to the number of pixels in the thermal sensor, such as 320×240 or 640×512. Higher resolution results in a sharper image and better target identification. ATN highlights that resolution becomes especially important when using digital zoom, as more pixels help preserve detail at higher magnification.
ATN also points out that these specs should not be evaluated separately. A high-resolution sensor with poor sensitivity may still produce a weak image in bad conditions, while a low-resolution sensor with excellent NETD may lack detail at distance. The best performance comes from a balanced combination of both.
In general, ATN presents thermal specifications as a way to predict real-world performance. Understanding NETD and resolution allows users to choose equipment based on actual needs rather than just numbers, making it easier to find a system that performs reliably in different environments.
