Player Spotlight: My Strongest Gear Crafted with Orb of Alchemy - Printable Version +- Mr Baddeley 3d Printed Droids Forum (https://forum.mbprinteddroids.com) +-- Forum: My Category (https://forum.mbprinteddroids.com/forumdisplay.php?fid=1) +--- Forum: My Forum (https://forum.mbprinteddroids.com/forumdisplay.php?fid=2) +--- Thread: Player Spotlight: My Strongest Gear Crafted with Orb of Alchemy (/showthread.php?tid=63596) |
Player Spotlight: My Strongest Gear Crafted with Orb of Alchemy - ShadowRift - 09-23-2025 Player Spotlight: My Strongest Gear Crafted with Orb of Alchemy When I first started playing Path of Exile 2, I didn’t understand how powerful the Orb of Alchemy could be. Over time, I learned that this small piece of PoE 2 currency could completely change an ordinary item into something strong and useful. Today, I’ll share how I crafted my strongest gear using this item, along with some simple tips that even beginners can follow. Why Orb of Alchemy is So Useful The Orb of Alchemy turns a normal (white) item into a rare (yellow) item with random mods. This means you can take a basic weapon or armor and make it much stronger. For example, I once used an Orb of Alchemy on a plain helmet, and it rolled high life, resistance, and even some mana regen. That helmet carried me through many tough fights. It shows that you don’t always need expensive gear—sometimes smart use of PoE 2 currency is enough. When to Use Orbs of Alchemy Here’s a tip: don’t waste them on items that are too low level. Instead, save your Orbs of Alchemy for items around your current level that you plan to use for a while. Good bases like wands, axes, or armor with the right defenses are perfect targets. Think of it like baking a cake—you want to use your best ingredients (your Orbs) only when the cake (the item) is worth it. Mixing With Other Currency Another trick is to combine Orb of Alchemy with other PoE 2 currency. For example:
Building Wealth with Currency If you want to buy PoE 2 currency instead of farming it for hours, trading is always an option. I once used u4gm to stock up quickly so I could focus on actually playing instead of grinding endlessly. It’s a nice shortcut when you just want to test a new build or push into higher maps faster. Final Tips for Strong Gear
