How to Score More Goals in EA FC 25: Advanced Attacking Tactics and Techniques - Printable Version
+--- Thread: How to Score More Goals in EA FC 25: Advanced Attacking Tactics and Techniques (/showthread.php?tid=55312)
How to Score More Goals in EA FC 25: Advanced Attacking Tactics and Techniques - LilyGreen - 02-14-2025
In EA FC 25, a powerful new technique has been introduced for crossing and passing: the driven ground cross. This method is incredibly effective and can significantly improve your attacking play. Here’s how to master it:
How to Execute the Driven Ground Cross:
  1. Hold R1 + L1 (PlayStation) or RB + LB (Xbox).
  2. Double-tap the Square button (or Cross on Xbox).
    • The first tap adjusts the power of the pass.
    • The second tap sends the ball low to the ground with a slight curve.
The driven ground cross can either target a far player (with more power) or a nearby player (with less power).
When to Use the Driven Ground Cross:
This technique is most effective when you’re positioned on the wing with a teammate in the box or cutting inside. The ball’s low, curved delivery makes it challenging for defenders to intercept, giving your teammates a better chance to score.
Best of all, this crossing method works well even if your player doesn’t have elite crossing stats, making it accessible and reliable across all skill levels.
Why the Driven Ground Cross Works:
  • It’s perfect for cutbacks, making it tough for defenders to block.
  • It’s more reliable than traditional crosses or passes, which can often be intercepted.
  • It consistently delivers the ball to your striker, even when you’re not using the best crossing player.
The Chip Shot Chip shots have become crucial in [color=var(--pri-color)]ea sport fc 25 coins, especially against aggressive goalkeepers. Here’s why you should incorporate them:[/color]
How to Perform a Chip Shot:
  • Hold L1 (PlayStation) or LB (Xbox).
  • Press the shoot button (Circle on PlayStation or B on Xbox).
Chip shots are ideal when the goalkeeper rushes out to challenge you. They help you avoid the easy saves that would result from a direct shot. Players with the Chip Shot trait or playstyle will benefit most from this technique.
Why Chip Shots Are Effective:
  • Goalkeepers rushing forward make chip shots nearly unstoppable.
  • Perfect for when the goalkeeper is out of position, allowing for a neat finish.
  • Especially useful in higher-level matches like Foot Champions.
How to Score More Goals Scoring in [color=var(--pri-color)]ea sports fc 25 coins is often about getting your players to make runs behind the defense. You can’t always rely on the AI to do this; you need to control it.[/color]
How to Trigger Runs Behind:
  • Press L1 (PlayStation) or LB (Xbox) and aim at the player you want to send in behind.
  • Alternatively, hold L1 or LB while passing to prompt your player to make a run.
Best Ways to Pass to a Player Running Behind:
  • Driven Pass: Hold R1 (PlayStation) or RB (Xbox) and pass to send a powerful ball.
  • Lob Through Ball: Hold L1 (PlayStation) or LB (Xbox), then press Triangle (PlayStation) or Y (Xbox) for a lobbed pass.
Why These Methods Work:
  • The driven pass is excellent for when your player is about to break through.
  • The lobbed pass is great for players with space and speed, especially when defenders are nearby.
FC 25 Attack Scenario Don’t worry if you’re struggling with your attack. Whether you’re using top-tier or budget players, we’ve got you covered. Let’s break it down step by step, starting with simple tactics and progressing to advanced ones.
Setting Up the Attack: Begin by ensuring players are in their correct positions. In the second half, mix things up to see how player positioning can affect your chances.
L1 Button for Player Movement: The L1 button is your friend for triggering runs. Even if your player has traits like RW+ (e.g., Son), sometimes they won’t automatically make those crucial runs, but L1 gives you control.
One-Two Passes to Unlock Space: One-two passes, especially backward ones, can be used to break down defenses and create overlaps. For example, after a quick one-two, you can set up a shot with players like Son.
Advanced Passing Techniques: Experiment with lob and precision passes, especially in tight spaces. For higher-level play, the L1+Triangle pass can break through defenses in the middle of the pitch.
Two Strikers for Flexibility: Having two strikers gives you more options. Your opponent can’t focus on just one player, which helps you create more opportunities. For example, if Son is isolated, having another striker like Swanson opens up space for better passing or shooting.
Defensive Integrity: While attacking is crucial, it’s equally important to maintain a solid defense. Don’t leave your backline vulnerable in search of goals. Always keep your defensive structure intact.
Using Overlaps and L1 for Better Attacks: Full-backs can be used in attack to create extra space for crosses or passes. If timed well, this tactic can work wonders.
Creating Shooting Opportunities: Precision shooting is essential for taking advantage of opportunities. Try angled shots for more accuracy, or power shots for long-range goals. With players like Son, use a 45-degree angle and finesse to increase your chances of success.
Substituting for Realistic Attacks: In the second half, bring in affordable yet effective players like Alvarez or Williams. While they may lack the stats of top players, smart positioning and use of L1 triggers can still lead to success.
Using Creative Runs for Attack: Creative runs are crucial for unlocking chances. Direct players into unmarked spaces, especially on the wings, and set them up for a pass or shot.
Confidence in Decision-Making: Lastly, trust your instincts with the ball. Even basic moves can be effective if you make quick, confident decisions, especially when the [color=var(--pri-color)]ea fc 25 coins is tight.[/color]
Summary:
  • Shot Placement and Power: Focus on precision and power, especially with players like Griezmann. Aim for the top corner for the best results.
  • Adjusting Play Style: If your opponent becomes passive, use L1 to trigger runs and create space for more attacking options.
  • Space Creation and Passing: Sometimes a lob pass can stretch the defense, and good timing can open up attacking opportunities.
  • Tackling and Defense: Be mindful that slide tackles can be unpredictable. Manual defending requires careful control, especially when defending tightly.
  • Mistakes and Rebounds: Keep track of your movements, as mistakes can happen. Be aware of how the left-stick dribbling feels, as it can be less fluid than expected.
  • Final Attacking Phase: In the final minutes, make short, precise passes to avoid losing possession. Pushing too aggressively might waste a crucial chance.
Score More Goals in FC 25:
To succeed in FC 25, scoring more goals is essential. Build the ultimate team by visiting [color=var(--pri-color)]U4GM’s FC 25 store to buy fc 25 coins safely and at a great price, giving you the edge to dominate the competition.[/color]
Related articles recommended: [color=var(--pri-color)]How to Securely Obtain EA FC 25 Coins Without Breaking Rules[/color]
