Great Soccer Betting Tips from a 10-Year Expert - Printable Version +- Mr Baddeley 3d Printed Droids Forum (https://forum.mbprinteddroids.com) +-- Forum: My Category (https://forum.mbprinteddroids.com/forumdisplay.php?fid=1) +--- Forum: My Forum (https://forum.mbprinteddroids.com/forumdisplay.php?fid=2) +--- Thread: Great Soccer Betting Tips from a 10-Year Expert (/showthread.php?tid=38778) |
Great Soccer Betting Tips from a 10-Year Expert - trankhoa856325 - 11-05-2024 Great Soccer Betting Tips from a 10-Year Expert What is soccer betting? Experience in Over/Under betting in soccer. All of this will be summarized in my soccer betting experience below. Read on to learn more. Special Tips When Betting on Soccer with Bookmakers To win in soccer betting, the first thing we need to do is gather data and statistics about the match we want to bet on. How do we collect data to achieve the best results? The gathered results will form the foundation for a strong bet. Therefore, you should pay attention to the following issues: - Results of recent matches - Head-to-head history - Recent form and condition of the players - Home or away match - Recent performance of both teams, including the impact of the england best players on the match outcome. Additionally, we should also pay attention to external information about the match, such as weather, working conditions, and the coach's mood (personal information, lifestyle, etc.). The Secrets of Bookmakers on Over/Under Betting Typically, each bookmaker will have different odds. To have the most effective betting strategy for yourself, the first thing we must do is compare the odds of different bookmakers. After researching the situation of both teams and information about the odds from reputable betting sites, we need to know the following: - Allocate your capital wisely if you choose to bet directly. Usually, bookmakers use algorithms to calculate and distribute data, so betting amounts and odds change continuously. If we do not calculate carefully and play recklessly, it's easy to lose all our capital. - Bookmakers have been very successful in creating anxiety in the psychology of players. Due to unstable psychology, it's easy to fall into the trap set by bookmakers due to the "Phantom Ball" phenomenon. Always remember to stay calm. Experience in Over/Under Betting – Soccer Betting Experience After many years of "fighting," I have accumulated quite a few tips and experiences in soccer betting, effective betting methods, and good soccer strategies. Today, I will share how to bet on soccer without losing or how to play Over/Under in soccer for your reference. Here are some tips we know: Soccer Betting Tip 1 First, I will explain the symbols in betting. H is the home team, and A is the away team. For example, in a friendly match between Japan and Uruguay in October 2018, initially, the bookmaker rated Uruguay (A) as the favored team with a handicap of 1/4 (0/0.5) with a full refund. Japan (H) was rated lower with a refund rate of 0.82. However, as the match was about to start, the bookmaker adjusted the odds to make Japan and Uruguay even. The odds changed to Japan having a full refund, while choosing Uruguay had a refund rate of 0.72. Therefore, we have a tip as follows: for matches like the one above, choose Japan (the lower-rated team) with a handicap of 0. From this, we can see: the initial odds from the bookmaker placed Uruguay as the stronger team with a handicap of 1/4 (0.5). However, as the match is about to start, the odds drop to even. This means that it has been calculated that the actual strength of the two teams differs from the initial assessment. Therefore, in such cases, choosing the underdog with a 0 handicap will have a very high winning rate. The dynamics of the game can often remind fans of the best italian soccer team, showcasing how predictions can shift based on performance. Football Betting Experience – Guide to Over/Under Betting Handicap Betting – VIP Betting Tips Based on my experience, a 1-goal handicap usually indicates that the favored team is significantly stronger than the underdog. This is more evident compared to a 1/4 or half-goal handicap. Betting on Over/Under in these handicap situations often leads to wins, with the worst case being a break-even. If you lose, it’s a sign to take a break because luck may not be on your side. I’m joking a bit, but I am confident that the winning rate for these handicap levels is much higher than for regular bets. So here is an effective football betting strategy: 1. Don’t choose the underdog; pick the stronger team with a -1 handicap. 2. Additionally, place a smaller bet on a draw in the European market. For example: - Bet on the stronger team with a 1-goal handicap of 2 million VND. - Bet 1 million VND on a draw in the European market. If the match ends in a draw, you will win nearly 2 million VND from the handicap and over 1 million VND from the draw. If the stronger team wins, you will profit nearly 1 million VND after deducting the draw bet. Remember, if the handicap is 1 goal, choose the stronger team (-1) and place half of your money on the European draw market. At the same time, focus on the main bets; this tip does not apply to live betting (running odds). Live Betting (Running Odds) This tip is especially for Over bets in live betting: 1. Stay calm and place bets slowly; haste can lead to losses. 2. Avoid making large bets or betting your entire amount. 3. Be selective with your bets; avoid betting on every opportunity. 4. Always keep an eye on high odds to place your money. 5. Choose matches that are likely to have many goals. 6. For live betting, select Over bets with odds lower than 1. Tips for Live Betting: - Don’t stay in live betting too long. Typically, you can win on handicaps like 3/4 (winning half your bet), but losses can be total. It’s better to leave when you have made a profit. Guide to Football Betting – Tips for Live Betting Experience with Over/Under Betting: Our ancestors often said that every lesson has its price, and that is true. I have also spent my account and learned many hard lessons. Let me share some key factors for live betting: 1. Learn how to bet Over/Under in the first half. 2. Choose matches likely to have high Over results. You can refer to the article: https://wintips.com/best-soccer-players-in-spain/ From my experience with virtual football and tips, these matches usually have many goals in the first or second half. You can use sites like tip providers to check the history and recent matches of the two teams. You will notice that some matches always result in Over, while others always result in Under. Example of Betting Strategy: For matches in the first half (HT) that often have many goals, bet Over 0.75-0.5 in the first half. But be careful: betting algorithms are very sophisticated, and odds can change within 5-10 seconds. If you continuously bet on matches with many goals, bookmakers will take notice. Always be vigilant to avoid falling into a loss situation. RE: Great Soccer Betting Tips from a 10-Year Expert - davidhamilton9943 - 01-21-2026 Hey there, after a heavy day at work I was looking for a distraction and stumbled onto a short recommendation in a comment thread. I started playing without a plan and lost several rounds back to back, which was frustrating enough to stop. Right in the middle I decided to test the aviator app and noticed it offers bonuses for players from Nigeria. I adjusted my timing, took one higher risk, and finally landed a solid win. It made the evening end on a better note. |
