Some things should not be carried out the door - Printable Version
+--- Thread: Some things should not be carried out the door (/showthread.php?tid=156030)
Some things should not be carried out the door - mrcFOT2O - 05-06-2026
A dining table your grandfather built. A oak parquet that has softened every footstep for twenty years. Plaster walls that have held every family photograph. These things belong where they are. On-site restoration of furniture, walls, and floors exists precisely for this reason — to repair without removing, to renew without uprooting.
Who We Are
Restavrator is not a moving company. We are restorers who travel to you. Our workshop is wherever your home is — one apartment, one room, one corner at a time. The team works in silence when needed, explains every step when asked, and cleans as thoroughly as we repair. We value old materials as much as new techniques. Our expertise covers furniture (solid wood, veneer, lacquered and polished surfaces), walls (plaster, drywall, decorative coatings), and floors (parquet, engineered wood, stone, ceramic). We are insured, referenced, and unusually patient with unusual problems.
What We Offer
  • On-site furniture repair — structural gluing, veneer patching, scratch and burn removal, hardware replacement, and full refinishing without taking pieces away.
  • Wall damage solutions — hairline cracks, deep holes, water-damaged plaster, peeling paint edges, and seamless blending of new and old textures.
  • Floor restoration — localized sanding and recoating, single plank replacement, stone chip filling, and grout repair for tiles.
  • Custom color matching — we photograph, scan, and manually blend finishes to make the repaired area truly invisible.
  • Fast cure times — most finishes dry within two to four hours. Rooms are usable the same evening.
Everything is done within your existing floor plan. No dismantling. No removal. No empty rooms.
When It’s Useful
  • A chair leg broke, but the rest of the set is perfectly fine. You do not want to reupholster or replace everything.
  • A wall socket came loose and cracked the plaster around it — a tiny problem that looks worse every day.
  • You have guests arriving tomorrow and a deep scratch across the dining table.
  • Wooden floors show a trail of wear from desk chairs or sofa legs, but the rest of the room is flawless.
  • A restoration project has been delayed because you cannot be without that table or cabinet for weeks.
  • You are tired of paint stores failing to match your existing wall color. We bring the match to the wall.
Why Choose Us
Because restoration should never make your life harder.
  • No logistics stress. You do not wrap, lift, carry, or store anything. We work around your belongings.
  • No construction mess. Dustless sanding, sealed tool containers, and full cleanup are part of every visit.
  • One team for all surfaces. A single person can restore a damaged table, a cracked wall, and a scuffed floor in one appointment — because they often happen together.
  • Local expertise. We know exactly how old Ukrainian and European furniture and finishes behave.
  • One-year guarantee on all on-site restoration work. If a repair fails under normal use, we return at no cost.
Most importantly, we never pretend a replacement is better than a repair. We are here because we believe the opposite.
Call to Action
Look closely at what wears down in your home. Then see how quietly it can be brought back — without a single box packed or a single wall torn open.
https://restavrator.in.ua/ru
