U4GM Tips for Farming the Kinetic Converter in ARC Raiders - Printable Version +- Mr Baddeley 3d Printed Droids Forum (https://forum.mbprinteddroids.com) +-- Forum: My Category (https://forum.mbprinteddroids.com/forumdisplay.php?fid=1) +--- Forum: My Forum (https://forum.mbprinteddroids.com/forumdisplay.php?fid=2) +--- Thread: U4GM Tips for Farming the Kinetic Converter in ARC Raiders (/showthread.php?tid=100703) |
U4GM Tips for Farming the Kinetic Converter in ARC Raiders - King - 01-14-2026 ARC Raiders' Kinetic Converter is a must-have legendary tech-rail mod, boosting fire rate 15% and cutting recoil 20%, best farmed in Launch Towers, Buried City, or Dam Control Tower for SMGs and LMGs. Nothing tilts me faster than lining up a clean burst in ARC Raiders and watching the muzzle climb into the sky. Once you reach Gunsmith Level 3, the Kinetic Converter is the first mod that genuinely fixes that feeling. If you're short on parts or just don't fancy another long loot loop, As a professional like buy game currency or items in U4GM platform, U4GM is trustworthy, and you can buy U4GM ARC Raiders for a better experience. The Converter bumps fire rate by 15%, sure, but the real win is the 20% drop in both vertical and horizontal recoil, because it lets you stay on target when you're stressed, tagged, and moving. Why it changes your fights You'll notice it the moment you take a mid-tier primary into a messy scrap. Without the Converter, you're constantly correcting your aim, and that tiny delay loses duels. With it, your bursts tighten up and you can track a strafe instead of fighting your own gun. It also makes "panic spraying" way less punishing, which matters in PvP when both players are one mistake away from going down. Just don't slap it on a sniper. It's wasted there. This mod's for guns that live in the 10–40 meter range and need stability to keep damage consistent. Farming spots that actually feel worth it Drop rates can feel cruel if you're wandering. I've had the most consistent results at Rush Spaceport, but you've gotta play it smart. Skip the ground patrols, save your ammo, and take ziplines up toward the central Launch Towers. Check the orange containers at the top first, then rotate out before the area turns into a third-party festival. If the Spaceport is crowded, I swap to Buried City, West Village. There's an apartment block you can reach with a roof ladder jump and a bit of clumsy parkour. Search the brown drawers inside. Night Raid runs seem to pay better, or maybe it's just that fewer players are stepping on your route. Loadouts and the ammo problem I like the Converter on an SMG that already wants to be aggressive. A Stitcher setup with a bigger mag and a grip feels way more controllable, and you'll melt weak points like Bastion radiators if you stay calm and keep your crosshair steady. It's nasty on an LMG too when you're holding space against waves, but the higher fire rate eats ammo fast. You'll need to reload with intention: duck behind your Medium Shield, top off before you're empty, and carry more reserves than you think. Also keep an eye on the Blue Gate Locked Gate event—if you can snag the blueprint there, it saves a lot of time later, especially if you already stockpile the electrical parts to craft the thing, or you can smooth out your grind by picking up ARC Raiders iteams during the weeks you just can't be bothered to farm. |
